With Automatic Transmission
Power Steering Pressure Switch (PSPS):
The Power Steering Pressure Switch (PSPS) is located in the high pressure side of the power steering hydraulic system. This switch CLOSES when the hydraulic pressure reaches approximately 400-600 psi. The idle speed is adjusted to compensate for the additional engine load when the PCM senses this pressure signal.
