Fuel Pressure Regulator: Service and Repair
1. Relieve fuel pressure.
2. Disconnect battery ground cable.
3. Disconnect the fuel tube from the pressure regulator.
4. Disconnect the fuel pressure regulator vacuum line.
5. Remove the fuel pressure regulator bolts.
1. Install the fuel pressure regulator and retaining bolts. Torque to 8-11 Nm (71-97 in lb).
2. Connect the fuel pressure regulator vacuum line.
3. Connect the fuel tube to the pressure regulator.
4. Connect battery ground cable.
5. Start engine and check for leaks.
