Automatic Transaxle
Idle Speed Adjustment:
1. Warm engine to operating temperature. Connect tachometer.
Data Link Connector:
2. Turn engine and all accessories Off. Ground PCM Self-Test Input (STI) pin at data link connector.
3. Start engine check idle speed. If not within specification, correct with idle speed adjustment screw.
IDLE SPEED: 650 - 750 rpm
4. Turn engine Off, remove STI ground, and let engine cool.
5. Start cold engine; idle speed should be higher than when warm.
