Throttle Body: Service and Repair
REMOVAL1. Remove the air intake system.
Throttle Body And Related Components:
2. Disconnect the Throttle Position (TP) sensor, Idle Air Control Bypass Air (IAC BPA) valve and the idle switch.
Accelerator Cable:
3. Disconnect the throttle cable.
4. Disconnect the throttle body coolant line.
5. Disconnect the IAC BPA coolant line.
6. Disconnect the vacuum lines from the throttle body.
7. Remove the throttle body mounting bolts and nuts.
Throttle Body:
8. Remove throttle body.
1. Install the throttle body mounting bolts and nuts and torque to 19-25 Nm (14-19 ft lb).
2. Connect the vacuum lines from the throttle body.
3. Connect the IAC BPA coolant line.
4. Connect the throttle body coolant line.
5. Connect the throttle cable.
6. Connect the TP sensor, IAC BPA valve and the idle switch.
7. Reinstall the air intake system.
