Throttle Cable/Linkage: Service and Repair
1. Remove accelerator cable from the accelerator lever.
2. Remove accelerator cable from the accelerator cable mounting bracket.
Accelerator Shaft Bracket:
3. Squeeze the lock tabs and remove the accelerator cable end from the accelerator pedal assembly.
Accelerator Cable:
4. Squeeze the lock tabs securing the accelerator cable housing to the bulkhead and remove the accelerator cable assembly.
1. Position the accelerator cable housing into the hole in the bulkhead and snap it into place.
2. Install the accelerator cable end on the accelerator pedal assembly and snap it into place.
3. Install the accelerator cable in the accelerator cable mounting bracket.
4. Install the accelerator cable end on the accelerator lever.
5. Adjust the pedal free play and the wide-open throttle position.
