Manual Transaxle
1. Disconnect negative battery cable.
2. Remove high-tension lead from coil by first twisting, then pulling it from ignition coil terminal.
3. Pull off connector cover.
4. Disconnect connector.
5. Remove coil attaching nut.
6. Remove coil.
1. Install ignition coil.
2. Install the ignition coil attaching nut and torque to 71-88 in. lb. (8-10 N-m).
3. Connect the ignition coil connector from the ignition coil.
4. Install ignition coil connector.
5. Install high-tension lead.
6. Connect battery ground cable.
