Air Bag - Lamp ON/Module Displays Code 34
Article No.93-17-3
08/18/93
^ AIR BAG - MODULE DISPLAYS SERVICE CODE 34 - VEHICLES BUILT THROUGH 9/30/93
^ LAMP - AIR BAG LIGHT COMES ON AND MODULE DISPLAYS SERVICE CODE 34 - VEHICLES BUILT THROUGH 9/30/93
FORD:
1993 PROBE
This TSB article is being republished in its entirety to correct the part number suffixes and part descriptions.
ISSUE:
The air bag light may come on and the module display service code 34 because the connector insertion bar is damaged or bent. The air bag system is equipped with a shorting bar in connector C257. This mechanism prevents the air bag module from deploying while service work is being performed. The insertion bar opens the shorting bar when the connector is together to activate the system. The insertion bar may become damaged or bent during the assembly or reassembly process.
ACTION:
Check the C257 connector in the steering column for a bent or damaged insertion bar, Figure 1. If it is damaged, install a new combination switch assembly which includes the C257 connector.
Parts Block
SUPERSEDES: 93-15-4
WARRANTY STATUS:
Eligible Under Bumper To Bumper Warranty Coverage
931703A Inspect And Replace 0.8 Hr.
Combination Switch
BASIC PART NO. CONDITION CODE
13K359 97
OASIS CODES: 104000, 206000
