Attachment III - Technical Instructions
Remove ignition coil wire. Be sure to note the location where the attaching clip fastens the coil wire to the air cleaner.
Insert the coil wire through the slip ring. Install coil wire and attach slip ring to the air cleaner at the location noted above.
NOTE:
IF THROUGH VISUAL INSPECTION OF THE IGNITION COIL, DAMAGE IS FOUND, REPLACE THE IGNITION COIL. REFER TO THE 1993 MODEL YEAR FORD PROBE SHOP MANUAL, SECTION 03-07, FOR THE IGNITION COIL REPLACEMENT PROCEDURE.
