Brake Drum: Service and Repair
Brake Drum Screws:
Removal
2. Remove the wheel and tire assembly.
3. Remove the hub grease cap.
4. Remove the two brake drum screws and remove the brake drum.
Installation
2. Tighten the brake drum screws to 10-14 N-m (89-123 lb-in).
3. Tighten the wheel hub bolt nut to 88-118 N-m (65-87 lb ft).
