Vacuum Vent Valve: Adjustments
Fig. 106 Vacuum Dump Valve Replacement:
When the brake pedal is released and in the upright position, the plunger of the vacuum dump valve should protrude 4-5 mm from the body. If plunger length is greater than specified, adjust valve position in the adjusting clip, Fig 106.
