Engine - Drone Noise From Engine Mount
Article No.
94-12-8
06/15/94
^ ENGINE - 2.5L MTX - "DRONE" NOISE FROM # 1 ENGINE MOUNT - GT MODELS BUILT FROM 4/16/92 THROUGH 11/30/93
^ NOISE - "DRONE" - FROM # 1 ENGINE MOUNT - GT MODELS BUILT FROM 4/16/92 THROUGH 11/30/93 WITH MTX
FORD:
1993-94 PROBE
This article is being republished in its entirety to specify transaxle type for affected vehicles.
ISSUE:
A "drone" noise from the # 1 engine mount may be heard when moving from a stop or when accelerating or decelerating in first gear. The engine moves back and forth causing the noise at the # 1 engine mount.
ACTION:
Install a new # 1 engine mount which has no liquid between the stopper rubber and outside rubber. Refer to the 1993 Probe Service Manual, Section 03-01B, for the removal and installation procedure.
PART NUMBER PART NAME CLASS
F42Z-6068-B Engine Mount - Rubber # 1 C
SUPERSEDES: 94-9-8
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
941208A Replace # 1 Engine Mount 1.0 Hr.
BASIC PART NO. CONDITION CODE
6068 56
OASIS CODES: 497000, 702000, 702100
