1. Visually inspect the components of the cigar lighter system.
2. Check the wiring harness for obvious signs of shorts, opens, bad connections or damage:
VISUAL INSPECTION CHART
Mechanical
- Damaged retaining fingers
Electrical
- Blown fuse: 15A AUDIO
- Damaged wiring harness
- Loose or corroded connections
- Damaged element
3. If fault is not visually evident, determine the symptom and proceed to the Symptom Chart. Symptom Related Diagnostic Procedures
