Warning Indicators
With the Ignition Switch in "START" or "RUN", voltage is present at the Low Washer Fluid, Door, Brake, Fasten Seat Belts, Door Ajar and Check Engine Indicator bulbs through the METER Fuse and circuit 41 (BK/Y). The bulb for each indicator is grounded under certain conditions as described.
