Instrument Cluster / Carrier: Service and Repair
1. Disconnect battery ground cable then isolate cable.2. Loosen hood release handle mounting nut.
3. Remove lower instrument panel cover screw.
4. Remove courtesy lamp from lower instrument panel cover by turning bulb 1/4 turn counterclockwise, then pulling bulb straight out.
5. Remove lower instrument panel cover, then five instrument cluster bezel screws.
6. Disconnect resistor panel lamp dimmer switch electrical connector.
7. Remove instrument cluster bezel.
8 Remove two upper steering column retaining bolts and lower steering column.
9. Remove four instrument cluster retaining screws.
10. Disconnect instrument cluster from electrical connectors, then remove cluster from vehicle.
11. Reverse procedure to install.
