Seat Belt Reminder Lamp: Description and Operation
Seat Belt Warning Indicator FunctionThe seat belt system incorporates a warning chime and indicator warning lamp. The chime is grounded by a switch in the buckle for the driver's seat belt. The warning chime will sound for approximately eight seconds unless the driver's belt is fastened. The indicator lamp remains on for approximately 10 seconds after the ignition switch is turned ON, whether or not the driver's seat belt is fastened.
With the driver's seat belt unbuckled, the Central Processing Unit (CPU) grounds the Fasten Belts Indicator. Current flows through the METER Fuse, the Fasten Belts Indicator and the CPU to ground, and the indicator illuminates.
