Temperature Gauge: Description and Operation
The temperature indicating system is a magnetic type system, which consists only of the sending unit located in the engine block or cylinder head and a temperature gauge in the instrument cluster. The sending unit changes resistance according to the temperature of engine coolant, which varies the current flow through the gauge. The pointer position varies proportionally to the current flow. The sender resistance is high when coolant temperature is low, and low when coolant temperature is high.
The pointer of the magnetic gauge remains in position when ignition is turned to the Off position. It will move to the correct indication whenever the ignition is turned back to On position.
