Part 2 of 3
Component Locations:
A/C CLUTCH CYCLING PRESSURE SWITCH
A/C CLUTCH FIELD COIL
A/C HIGH PRESSURE SWITCH
A/C RELAY
A/C THERMAL PROTECTION SWITCH
ALTERNATOR
CONDENSER FAN MOTOR
COOLING FAN MOTOR
DISTRIBUTOR
DRL RELAY
ENGINE COMPARTMENT FUSE BOX
FOG LAMP RELAY
FUEL PUMP RELAY
HEADLAMP RELAY
HEADLAMP RETRACTOR TEST CONNECTOR
HIGH SPEED CONDENSER FAN RELAY
HIGH SPEED COOLING FAN RELAY
HORN RELAY
JOINT CONNECTOR
LOW SPEED BLOWER MOTOR RELAY
LOW SPEED CONDENSER FAN RELAY
LOW SPEED COOLING FAN RELAY
PARK LAMP RELAY
PARK/NEUTRAL POSITION SWITCH (MANUAL)
PCM POWER RELAY
PULSE SIGNAL GENERATOR (AUTOMATIC)
REAR WINDOW DEFROST RELAY
STARTER INTERRUPT RELAY
STARTER MOTOR
STARTER MOTOR (MANUAL)
TRANSAXLE CONTROL SOLENOID VALVE (AUTOMATIC ONLY)
