Air Flow Meter/Sensor: Service and Repair
REMOVAL1. Disconnect negative battery cable.
Air Induction System Components:
2. Disconnect the electrical connector from the Measuring Core - Volume Air Flow (MC-VAF) meter.
3. Loosen the engine air cleaner tube clamp on the MC-VAF meter side of the air cleaner to intake manifold tube.
4. Remove air cleaner to intake manifold tube from the MC-VAF meter.
5. Remove the two bolts and remove MC-VAF meter from the engine air cleaner upper cover.
1. Install the MC-VAF meter to engine air cleaner upper cover. Torque attaching bolts to 8-10 Nm (71-88 in lb).
2. Install air cleaner to intake manifold tube.
3. Tighten engine air cleaner tube clamp on MC-VAF meter side of the air cleaner to intake manifold tube.
4. Connect the MC-VAF meter electrical connector.
5. Connect negative battery cable.
