Clutch Switch: Service and Repair
Clutch Pedal Assembly:
2. Disconnect electrical connector from the back of the CPP switch.
3. Rotate the CPP switch 90° in either direction and remove it from the mounting bracket.
1. Install the CPP switch into the mounting bracket and rotate 90° in either direction.
2. Connect the CPP electrical connector.
3. Connect the battery ground cable.
