Component Tests
Clutch Switch Inspection:
1. Disconnect clutch switch connector.
2. Check switch continuity with an ohmmeter. With clutch pedal depressed, there should be continuity between switch terminals. With clutch pedal released, there should be no continuity between switch terminals.
3. Reconnect clutch switch connector after testing or replacement.
