Throttle Position Sensor: Service and Repair
REMOVAL1. Disconnect negative battery cable.
2. Disconnect Throttle Position (TP) sensor electrical connector.
3. Remove two TP sensor set screws and lift sensor from throttle body.
1. Open the throttle slightly to align the tab A and tab B of the TP sensor to the throttle body.
2. Align the mounting holes and install the TP sensor.
3. Check that tab A and tab B are properly aligned. Properly adjust TP sensor. Adjustments
4. Tighten the TP sensor set screws to 2.0 Nm (14-20 lb in).
5. Connect the battery ground cable.
