Throttle Position Switch: Adjustments
1. Disconnect the Throttle Position (TP) sensor connector.Idle Switch:
2. Connect Rotunda Digital Volt-Ohmmeter 105-00051 or equivalent to the Data Link Connector (DLC) terminals IDL and GND.
Idle Switch:
3. Insert a 0.15 mm (0.006 inch) feeler gauge between the stopper and the throttle lever.
4. Continuity should exist.
5. Insert a 0.50 mm (0.020 inch) feeler gauge between the stopper and the throttle lever.
6. Continuity should not exist.
7. If not within specifications, adjust the TP sensor. Refer to Throttle Position Sensor/Adjustments. Adjustments
