Air Cleaner Fresh Air Duct/Hose: Service and Repair
Air Intake Tube:
1. Loosen and slide the engine air cleaner intake tube away from the fitting.
2. Remove the three nuts from the engine air cleaner intake tube and remove the engine air cleaner intake tube.
To install, reverse the removal procedure. Tighten the engine air cleaner intake tube nuts to 8-10 Nm (71-88 lb in).
