Fuel Pump: Description and Operation
Fuel Pump:
Provides pressurized fuel to the fuel injectors.
CONSTRUCTION
The pump is an impeller type hydraulic unit directly coupled to a permanent magnet motor. Fuel is used as a lubricant and coolant for the motor. A check valve is incorporated in the fuel outlet and a pressure limiter valve is located on the pressure side of the fuel pump housing with a return passage to the fuel inlet side.
When the impeller rotates, a pumping action is created. The circulating impeller draws in fuel at the inlet port and force fuel through the outlet port into the fuel system.
When the pump is shut off, the check valve in the fuel outlet will close, therefore prohibiting the fuel from returning to the fuel tank via the fuel pump. The check valve will therefore maintain a pressure in the fuel lines called the "rest pressure".
The maximum fuel pump pressure (not fuel system pressure) is dependent on the calibration of the pressure limiter. If the fuel pump pressure exceeds a preset limit (for example a clogged fuel filter), the pressure limiter will open a by-pass to the fuel inlet side of the pump.
