Vacuum Reservoir: Service and Repair
1. Remove the intake manifold. Refer to Section 03-01B.
NOTE: Label and Identify the vacuum chamber vacuum hoses before removal.
Variable Resonance Induction System Vacuum Chambers:
2. Disconnect the vacuum hoses from the VRIS vacuum chambers.
3. Remove the two bolts from each vacuum chamber.
4. Remove the vacuum chambers from the intake manifold.
