Variable Induction Control Solenoid: Description and Operation
Variable Resonance Induction System (VRIS) is operated by two PCM controlled solenoid valves. When solenoids are activated, vacuum is applied to shutter valve actuators. Actuators manipulate shutter valves inside the intake manifold. System improves charging efficiency and torque characteristics.
