Variable Induction Control Solenoid: Service and Repair
Solenoids:
2. Disconnect the VRIS solenoid electrical connectors.
Solenoids:
3. Remove the two VRIS solenoid bracket bolts.
4. Disconnect the VRIS solenoids from the VRIS solenoid bracket.
NOTE: Identify and label the VRIS solenoid vacuum hoses before disconnecting them.
5. Disconnect the vacuum hoses from the VRIS solenoids.
6. Remove the VRIS solenoids from the vehicle.
