Engine Control Module: Service and Repair
Powertrain Control Module:
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
2. Remove the Powertrain Control Module (PCM) console panel access panel, located in front of the shift control selector lever and housing.
3. Disconnect the electrical connectors from the PCM.
4. Remove the two PCM bolts.
5. Remove the PCM from the console panel.
1. Install PCM to the console panel.
2. Install the two PCM bolts.
3. Connect electrical connectors to the PCM.
4. Install the PCM console panel access panel.
5. Connect the battery ground cable.
