Glossary Of Terms Used In Pinpoint Tests
The terms below are used to direct actions during diagnostic procedures. They are provided here with a thorough description of the action intended.
Air Bag Simulator
Rotunda Air Bag Simulator 105-00009 is used to simulate air bag connection to the system.
Disconnect Component
Disconnect component means disconnect the component connector and vehicle harness connector. It does not mean remove the component. Also, a disconnected component should not be reconnected unless instructions state otherwise.
Deactivate System
Deactivate system means to perform the Air Bag(s) Arming and Disarming Procedures.
Prove Out System
Prove Out system means to turn the ignition switch from OFF to ON and visually monitor the Air Bag Lamp. The diagnostic monitor illuminates the Air Bags Lamp for approximately 6 seconds and then turns off. This indicates that the air bag lamp is operational. If the air bag lamp does not illuminate or if the lamp stays on or flashes at any time, a fault has been detected by the diagnostic monitor.
Reactivate System
Reactivate system means to perform the Air Bag(s) Arming and Disarming Procedures. THE AIR BAG SIMULATOR MUST BE REMOVED AND THE AIR BAG RECONNECTED BEFORE THE SYSTEM IS REACTIVATED.
Reconnect System
Reconnect system means to reconnect all system components.
Replace Component
Replace component means to remove the existing component and replace it with an authorized replacement part. Also, the replacement component should be installed on the vehicle and all necessary electrical connections must be completed.
Verify System
Verify system means to prove out the system with an air bag simulator in place of the air bag.
