Front Seat Belt Buckle
Removal1. Slide the front seat as far rearward as possible.
2. Remove the buckle anchor bolt.
3. It removing the driver's buckle, disconnect the seat belt warning switch under the driver's seat.
4. Remove the seat belt buckle.
Installation
1. Position the belt buckle on the seat and install the anchor bolt. Tighten the anchor bolt to 38-78 Nm (28-58 lb-ft).
2. If installing the driver's seat belt buckle, connect the seat belt warning switch under the driver's seat.
