Power Steering Pump: Service and Repair
1. Remove high pressure line hold-down bracket bolt, then the high pressure line banjo bolt.
2. Raise and support vehicle, then remove passenger side front wheel.
3. Remove passenger side splash shield.
4. Loosen power steering pump adjusting bolt, then remove power steering pump drive belt.
5. Insert a screwdriver through hole in pump pulley, then remove retaining nut and pulley.
6. Remove two supply line manifold bolts from power steering pump.
7. Disconnect power steering pump pressure switch electrical connector.
8. Remove four power steering pump bracket to engine block retaining bolts.
9. Remove power steering pump from vehicle.
10. Reverse procedure to install. Install new banjo bolt crush washers.
