Rear Suspension Front Lateral Link
1. Raise and support vehicle.
2. Remove spindle through bolt, then position a suitable jack beneath rear crossmember.
3. Remove four crossmember to frame retaining bolts.
4. Lower rear crossmember assembly to gain access to front lateral link to rear crossmember retaining bolt.
5. Remove access hole cap, then the front lateral link to rear crossmember retaining bolt.
6. Remove front lateral link from vehicle.
7. Reverse procedure to install.
8. Check wheel alignment.
