A/C O Ring - Availability and Applications
Article No.96-20-7
09/23/96
AIR CONDITIONING - NEW 0-RING AVAILABILITY AND APPLICATIONS - SERVICE TIP
FORD:
1992-93 FESTIVA
1992-94 TEMPO
1992 and after ESCORT, MUSTANG, PROBE, TAURUS, THUNDERBIRD
1994 and after ASPIRE
1995 and after CONTOUR
LINCOLN-MERCURY:
1992-94 TOPAZ
1992 and after CONTINENTAL, COUGAR, SABLE, TRACER
1993-94 CAPRI
1993 and after MARK VIII
1995 and after MYSTIQUE
LIGHT TRUCK:
1992 and after AEROSTAR, BRONCO, ECONOLINE, EXPLORER F-150-350 SERIES, F-47, RANGER
1993 and after VILLAGER
1995 and after WINDSTAR
1997 and after MOUNTAINEER
MEDIUM/HEAVY TRUCK:
1992 and after F & B SERIES
ISSUE:
This bulletin provides climate control system O-ring part number information.
ACTION:
When servicing A/C systems, refer to the application charts for correct O-ring part numbers.
The contents of O-ring Service kit F3VY-19D690-A* are as follows:
^ Two (2) 391304-S100**
^ Two (2) 391305-S100
^ Two (2) 391396-S100**
^ Four (4) 391397-S100**
* This O-ring kit will be obsolete and new O-rings will need to be ordered separately.
** These Part Numbers have been replaced by new thicker O-rings. They can be used until stock is depleted. The following are replacement numbers:
^ 391302-S100 replaced by W701993-S
^ 391303-S100 replaced by W701992-S
^ 391304-S100 replaced by W701994-S
^ 391396-S100 replaced by W701993-S
^ 391397-S100 replaced by W701992-S
Parts Block
OTHER APPLICABLE ARTICLES: 95-2-2
OASIS CODES: 208000, 208200, 208999
