A/T - G4A-EL and F4EAT Trouble Code Identification
Date: 1996Technical Bulletin # 364
Transmission:
G4A-EL & F4EAT
Subject:
Code 6 or 60 Present
Application:
Ford & Mazda
G4A-EL and F4EAT Code Identification
Care should be taken when Retrieving codes through the on board diagnostics.
Code 6 is displayed as six short flashes (or beeps). Code 60 is displayed as six long flashes (or beeps).
Use the chart to help prevent a misdiagnosis, see the chart.
Tip:
Disconnect the throttle position sensor. Make sure code 12 is displayed. Use the pattern for code 12 to help identify codes 6 or 60.
