Procedure C
1. Open the hood.
2. Remove the seal plate from the vehicle and discard. Save the five (5) attaching clips.
3. Remove one (1) bolt and one (1) nut that secures bumper set plate and save.
4. Slightly pry up the bumper set plate. Clean the shroud upper plate. Affix the rubber seal (180 mm long) along the shroud upper plate crease as indicated.
Discard 80 mm and 55 mm long rubber seals included in the service kit.
5. Reinstall the bumper set plate nut and bolt.
6. Fasten new seal plate by using five (5) original clips and two (2) washers as shown. Make certain that you install two (2) washers in the proper positions as indicated.
7. Discard one (1) washer, two (2) clips and two (2) rubber seals included in kit.
