Air Dam - Skirt Loose At Front Crossmember
Article No.
94-16-1
08/10/94
^ AIR DAM SKIRT (VALANCE) - LOOSE - AT FRONT CROSSMEMBER - BUILD DATES 4/16/92 TO 2/21/94
^ LOOSE AIR DAM SKIRT (VALANCE) - AT FRONT CROSSMEMBER - BUILD DATES 4/16/92 TO 2/21/94
FORD:
1993-94 PROBE
ISSUE:
The front air dam skirt (valance) may be loose at the front crossmember. This may be caused by loose or missing attaching grommets (thereby, only one bolt may be retaining the air dam skirt). New production has added an additional bolt to the skirt assembly.
ACTION:
To prevent/repair this problem, refer to the following procedure.
REPAIR PROCEDURE:
Replace the factory installed grommets with aftermarket license plate nuts, screws and washers.
1. Insert nylon nuts into the crossmember.
2. Install the air dam skirt by using washers and screws as shown in Figure 1.
Ford recommends the use of Auveco fasteners. These fasteners are available through Sarjo (1-800-447-2756).
Parts Block
WARRANTY STATUS:
Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
941601A Remove Grommets And 0.3 Hr.
Replace With Nylon Screws
And Nuts
BASIC PART NO. CONDITION CODE
17626 57
OASIS CODES: 108000, 402000
