Interval Wipers
Battery voltage is applied to the Combination Switch and the Windshield Wiper Motor through the WIPER Fuse with the Ignition Switch in "RUN". The Combination Switch receives ground via circuit 50 (BK) while the Windshield Wiper Motor is case grounded.
LO/HI MODE
When the Wiper Switch is put in the "LO" position, battery voltage is applied to the Windshield Wiper Motor "LO" speed input via circuit 125 (BL/W). The motor runs at "LO" speed. When the Wiper Switch is put in the "HI" position, battery voltage is applied to the Windshield Wiper Motor "HI" Speed input via circuit 126 (R). The Motor runs at "HI" Speed.
MIST
When the Mist Switch is in the "ON" position, battery voltage is applied to the Windshield Washer Motor the motor runs as long as the Mist Switch is held.
PARK
When the Wiper Switch is moved to the "OFF" position, battery voltage is piped from the WIPER Fuse through the Park Switch to the Windshield Wiper Motor. As the wipers move to the park position, battery voltage through the Park Switch is interrupted and the wipers come to rest in the "PARK" position.
INTERVAL
When the Wiper Switch is in the "INT" position, battery voltage is applied to the solid state circuitry within the Combination Switch. The solid state circuitry energizes the Interval Relay periodically, depending on the Interval Rheostat position. Battery voltage is applied briefly to the Windshield Wiper Motor. The motor brings the wipers out of the park position, to wipe the windshield and park at evenly spaced intervals.
WASHER
When the Washer Switch is activated, battery voltage is applied to the Windshield Washer Motor, the washer sprays fluid from the washer fluid reservoir. At the same time, battery voltage is applied to the Wiper Relay within the Combination Switch and the relay contacts close applying battery voltage to the Windshield Wiper Motor. The wipers wipe briefly before parking.
