Manufacturer Code Charts
CODE AFFECTED CIRCUIT PINPOINT TEST
02 Crankshaft Position Sensor 2 CKP2 CKP2 - Crankshaft Position Sensor No. 2
03 Camshaft Position Sensor CMP CMP - Camshaft Position Sensor
04 Crankshaft Position Sensor 1 CKP1 CKP1 - Crankshaft Position Sensor No. 1
05 Knock Sensor KS KS - Knock Sensor
08 Air Flow Sensor MC-VAF MC/VAF - Measuring Core/Volume Air Flow Sensor
09 Engine Coolant Temperature ECT ECT - Engine Coolant Temperature Sensor
10 Intake Air Temperature IAT IAT - Intake Air Temperature Sensor
12 Throttle Position Sensor TP TP - Throttle Position Sensor
14 Barometric Pressure Sensor BARO BARO - Barometric Pressure Sensor
15 Heated Oxygen Sensor HO2S HO2S - Heated Oxygen Sensor
16 EGR Valve Position Sensor EVP EVP - Exhaust Gas Recirculation Valve Position Sensor
17 Heated Oxygen Sensor HO2S HO2S - Heated Oxygen Sensor
23 Heated Oxygen Sensor HO2S HO2S - Heated Oxygen Sensor
24 Heated Oxygen Sensor HO2S HO2S - Heated Oxygen Sensor
25 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
26 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
28 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
29 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
34 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
41 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
46 Solenoid Controlled By Ground SCG SCG - Solenoid Controlled By Ground
67 Relay Output Check ROC ROC - Relay Output Check
CODES NOT LISTED PGC PGC - Power and Ground Connections
