Clearing Trouble Codes
PROCEDURE NOTES:
a. The indicator should illuminate while performing the memory cancel.
b. When the memory cancel operation is completed, the indicator should illuminate for 2-3 seconds, then go OFF.
c. After memory cancel, the anti-lock brake control module performs self-diagnosis.
d. Memory is not canceled by disconnecting the battery.
e. Memory codes cannot be canceled if the following occur:
- Intervals for depressing the brake pedal exceed one second.
- Stoplamp bulb or Brake ON/OFF (BOO) switch has malfunctioned.
f. If using the analog VOM, be sure to remove the jumper wire from the Data Link Connector (DLC) after all checks and repairs are made.
USING ANALOG VOM:
1. Connect pins "TBS" and "GND" at Data Link Connector (DLC) with jumper wire.
2. Key ON.
3. Output diagnostic trouble codes using the analog VOM.
4. After the first code is repeated, depress the brake pedal 10 times at intervals of less than one second.
5. Key OFF.
6. Disconnect the jumper wire at the DLC.
USING SUPER STAR II:
1. Connect Super STAR II tester to the DLC with Super MECS Adapter 007-00052.
2. Key ON.
3. Output diagnostic trouble codes using Super Star II Tester.
4. After the first code is repeated, depress the brake pedal 10 times at intervals of less than (1) second.
5. Key OFF.
6. Disconnect Super STAR II tester from the DLC.
