S100 - S230
Splice LocationS100 (Without Speed Control or With Anti-Lock Brake System (ABS)), Front harness, in T/O to engine compartment fuse box
S101 Front harness, near Take Out (T/O) to left headlamp retractor
S102 Front harness, in T/O to engine compartment fuse box
S103 Front harness, near safety wall grommet
S104 (Manual), Emission harness, near T/O to distributor
S105 Front harness, near T/O to right front combination lamp
S106 (Without Speed Control or With ABS), Front harness, near T/O to left headlamp
S109 Front harness, near safety wall grommet
S110 Engine harness, near T/O to G104
S111 Front harness, near T/O to electric cooling fan motor
S119 Front harness, near T/O to hood switch
S123 (Automatic), Emission harness, near T/O to transaxle control solenoid valve
S123 (Manual), Emission harness, near T/O to distributor
S125 Emission harness, near T/O to G106
S126 (Automatic), Emission harness, near T/O to G106
S126 (Manual), Emission harness, near T/O to distributor
S130 Front harness, near T/O to left headlamp
S133 Emission harness, near T/O to ignition control module
S134 Front harness, near safety wall grommet
S135 Front harness, near safety wall grommet
S138 Emission harness, near T/O to Heated Oxygen Sensor (HO2S)
S140 Front harness, near T/O to hood switch
S141 Front harness, in T/O to engine compartment fuse box
S142 Front harness, LH rear of engine compartment
S143 (Without Speed Control or With ABS), Front harness, in T/O to engine compartment fuse box
S147 Front harness, in T/O to engine compartment fuse box
S148 Front harness, LH rear of engine compartment
S149 Emission harness, near T/O to HO2S
S150 (Automatic), Emission harness, near T/O to Transmission Range (TR) sensor
S150 (Manual), Emission harness, near T/O to G105
S151 Front harness, LH rear of engine compartment
S152 Front harness, near safety wall grommet
S153 Front harness, near safety wall grommet
S154 Front harness, near safety wall grommet
S155 Front harness, near safety wall grommet
S156 Front harness, near safety wall grommet
S157 Front harness, near safety wall grommet
S158 (Without Speed Control or With ABS), Front harness, near safety wall grommet
S159 Emission harness, in T/O to TR sensor
S160 Emission harness, near T/O to TR sensor
S161 Emission harness, near T/O to G105
S162 Front harness, near T/O to left and right horns
S163 Emission harness, near T/O to G105
S165 Engine harness, near T/O to fuel injector #1
S166 Front harness, LH rear of engine compartment
S168 Front harness, LH rear of engine compartment, near safety wall grommet
S170 Front harness, near safety wall grommet
S171 Front harness, in T/O to engine compartment fuse box
S172 Front harness, near T/O to G103
S174 Front harness, LH rear of engine compartment
S175 Front harness, LH rear of engine compartment
S177 Front harness, near T/O to electric cooling fan motor
S178 Front harness, LH rear of engine compartment, near safety wall grommet
S180 Emission harness, near T/O to C126
S182 (Automatic), Engine harness, near T/O to G101
S182 (Manual), Engine harness, near T/O to right HO2S
S184 Front harness, near T/O to speed control servo
S185 Front harness, near T/O to G102
S188 Front harness, near T/O to left headlamp
S189 Front harness, near T/O to engine compartment fuse box
S190 (Manual), Emission harness, near T/O to G105
S190 (Automatic), Emission harness, near T/O to distributor
S191 Emission harness, near T/O to distributor
S192 (Automatic), Emission harness, near T/O to A/C clutch cycling pressure switch
S192 (Manual),Emission harness, near T/O to G105
S193 (Automatic),Emission harness, near T/O to TR sensor
S193 (Manual), Emission harness, near T/O to G106
S194 Emission harness, near T/O to C151
S195 Engine harness, near T/O to EGR valve position sensor
S199 Front harness, near T/O to electric cooling fan motor
S200 Instrument Panel (I/P) harness, in T/O to radio connector C211
S202 Front harness, near T/O to ignition switch
S203 Front harness, near T/O to G201
S206 I/P harness, in T/O to instrument cluster connector C240
S207 I/P harness, near T/O to G203
S208 I/P harness, near T/O to rear defrost switch
S210 Rear harness, in T/O to C268
S211 Emission harness, near T/O to C249
S213 I/P harness, near T/O to G203
S214 Front harness, in I/O to C206
S215 I/P harness, near T/O to C206
S216 I/P harness, near T/O to instrument cluster connector C240
S219 Front harness, near safety wall grommet
S220 Emission harness, near T/O to powertrain control module
S221 Rear harness, at LH door sill
S222 Rear harness, at LH door sill
S225 (without Speed Control or With ABS), Front harness, near T/O to combination switch
S226 Front harness, near safety wall grommet
S228 I/P harness, near T/O to joint connector C269
S229 Front harness, in T/O to engine compartment fuse box
S230 Rear harness, near T/O to C204
