S231 - S2014
Splice Location
S231 Front harness, near Take Out (T/O) to interior fuse panel connector C214
S232 Instrument Panel (I/P) harness, near T/O to G203
S233 I/P harness, near T/O to heater-A/C switch
S234 I/P harness, near T/O to heater-A/C switch
S236 Front harness, near safety wall grommet
S237 Front harness, near T/O to ignition switch
S238 Rear harness, at LH door sill
S239 Emission harness, near T/O to Powertrain Control Module (PCM)
S240 Emission harness, in T/O to transaxle control module connector C258
S241 I/P harness, near T/O to G200
S242 I/P harness, near T/O to C249 and C255
S244 I/P harness, near T/O to heater-A/C switch
S245 I/P harness, near T/O to rear window defrost switch
S246 Rear harness, in T/O to C268
S247 Rear harness, near T/O to power door lock relay
S248 Rear harness, near T/O to power door lock relay
S249 Rear harness, in T/O to C268
S250 Rear harness, near T/O to C308
S251 Rear harness, near T/O to park brake switch
S252 I/P harness, near T/O to C206
S253 Rear harness, in T/O to C200
S254 I/P harness, near T/O to C206
S256 Emission harness, near T/O to PCM
S257 Emission harness, near T/O to PCM
S258 Rear harness, at LH door sill
S260 (Automatic), Emission harness, near T/O to PCM
S260 (Manual), Emission harness, near safety wall grommet
S261 I/P harness, near T/O to G200
S262 Rear harness, near T/O to C290
S264 Rear harness, in T/O to C268
S265 Rear harness, in T/O to C268
S266 Front harness, near T/O to ignition switch
S267 Cigar lighter jumper harness, near T/O to C233
S268 Cigar lighter jumper harness, near T/O to C233
S269 I/P harness, in T/O to I/P dimming module
S271 I/P harness, near T/O to I/P connector C240
S273 I/P harness, behind center of I/P near LH edge of harness channel
S274 I/P harness, in T/O to instrument cluster C241
S275 I/P harness, in T/O to instrument cluster C241
S276 I/P harness, near T/O to G200
S277 Engine harness, in T/O to PCM
S278 Emission harness, in T/O to PCM
S279 Emission harness, near T/O to PCM
S281 I/P harness, near T/O to heater-A/C switch
S282 Front harness, near T/O to brake on/off switch
S283 I/P harness, near T/O to C206
S284 I/P harness, near T/O to joint connector C269
S285 Emission harness, near T/O to PCM
S286 Emission harness, near safety wall grommet
S287 Emission harness, near T/O to PCM
S288 Rear harness, at LH door sill
S289 I/P harness, in T/O to I/P dimming module
S290 Emission harness, in T/O to PCM
S291 Emission harness, near safety wall grommet
S292 Emission harness, near safety wall grommet
S293 Rear harness, at LH door sill
S295 Front harness, near T/O to interior fuse panel connector C214
S296 Emission harness, near T/O to PCM
S297 Front harness, near T/O to G201
S299 Emission harness, near T/O to PCM
S300 Rear harness, near T/O to C204
S301 Rear harness, near T/O to right rear speaker
S302 Rear harness, near T/O to C302
S303 Rear harness, near T/O to C302
S304 Rear harness, near T/O to park brake switch
S305 Rear harness, near T/O to C303
S306 Rear harness, near T/O to C302
S307 Power seat switch harness
S308 Rear harness, near T/O to park brake switch
S309 Rear harness, near T/O to park brake switch
S310 Power seat switch harness
S311 Rear harness, near T/O to park brake switch
S312 Rear harness, near T/O to C302
S313 Power seat switch harness
S314 Power seat switch harness
S315 Rear harness, near T/O to C303
S316 Rear harness, near T/O to right rear wheel speed sensor
S400 Rear harness, near T/O to inertia fuel shutoff switch
S401 Rear #3 harness, near T/O to G401
S402 Rear #2 harness, near T/O to C410
S403 Rear #2 harness, near T/O to C414
S404 Rear harness, near T/O to C427
S405 Rear harness, near T/O to luggage compartment lamp
S406 Rear harness, near T/O to Inertia Fuel Shutoff (IFS) switch
S409 Rear harness, near T/O to C303
S410 Rear harness, near T/O to IFS switch
S500 LH door harness, near T/O to left power/heated mirror
S501 LH door harness, near T/O to master window/door lock control switch
S502 LH door harness, near T/O to master window/door lock control switch
S503 LH door harness, near T/O to master window/door lock control switch
S504 LH door harness, near T/O to left power mirror
S505 LH door harness, near T/O to master window/door lock control switch
S600 RH door harness, near T/O to right power mirror
S601 RH door harness, near T/O to right power mirror
S602 RH door harness, near T/O to right window/door lock control switch
S603 RH door harness, near T/O to right power mirror
S900 Room harness, near T/O to left vanity mirror lamp
S901 Room harness, near T/O to left vanity mirror lamp
S2000 I/P harness, near I/O to C255 and C249
S2001 I/P harness, near T/O to C255 and C249
S2003 Emission harness, near safety wall grommet
S2007 Emission harness, near T/O to PCM
S2008 Emission harness, near T/O to PCM
S2009 Emission harness, near PCM
S2011 Emission harness, near T/O to PCM
S2012 Emission harness, near safety wall grommet
S2014 Front harness, near safety wall grommet
