Probe V6-153 2.5L DOHC
Powertrain Management
Computers and Control Systems
Auxiliary Air Valve (Idle Speed)
Component Tests
Component Tests
1.
Remove the
throttle body
2.
Measure the resistance of the Idle Air Control Bypass Air
(IAC-BPA)
valve. The resistance should be
10.7-12.3 ohms @ 20°C (68°F).
3.
If resistance is not as specified, replace IAC-BPA valve.
