Breakout Box Connection
PURPOSEThe Breakout Box is connected to the Powertrain Control Module (PCM)harness to pinpoint faults in the Electronic Engine Control (EEC) system.
CONNECTION
Disconnect the PCM connectors and attach Breakout Box 014-00322, with adapter T92C-6000-AH, to the harness connectors and to the PCM.
Breakout Box Adapter:
NOTE: Adapter T92C-6000-AH has two cables; use cable #2 as shown in the image.
NOTE: The adapter also has an A/B position selector switch. Make sure that the switch is in the correct position for each test step, as specified in the Circuit Data Sheets for EEC Pinpoint Tests Relay Output Check (ROC), Solenoid Controlled by Ground (SCG), and 4EAT Pinpoint Test Solenoid Controlled by Power (SCP). If no switch position is given, then the switch can be in either position.
