Vehicle Speed Sensor: Service and Repair
2. Remove the engine air cleaner.
3. Disconnect the electrical connector from the Vehicle Speed Sensor (VSS).
4. Remove the VSS bolt.
5. Remove the vehicle speed sensor from the transaxle.
1. Replace the O-ring.
2. Install the VSS bolt and tighten to 8-10 Nm (71-88 lb in).
3. Connect the electrical connector.
4. Install the engine air cleaner.
5. Connect the battery cable.
