Accelerator Pedal: Service and Repair
1. If equipped with speed control, remove the speed control actuator from the accelerator pedal shaft lever.
2. Remove the accelerator cable end from the accelerator pedal and shaft.
Accelerator Shaft:
3. Remove the three accelerator shaft retainer bolts.
Accelerator Pedal Assembly:
4. Remove the accelerator shaft retainer.
5. Release the accelerator shaft spring on the accelerator pedal and shaft.
6. Remove the retaining clip on the accelerator pedal and shaft.
7. Slide the accelerator pedal and shaft out and remove the accelerator shaft spring.
To install, reverse the removal procedure. Tighten the accelerator shaft retainer bolts to 8-10 Nm (71-88 lb in).
