Auxiliary Air Valve (Idle Speed): Description and Operation
Idle Air Control Bypass Air Valve:
The By-Pass Air (BPA) valve increases idle speed during cold engine conditions to speed engine warm-up and prevent cold engine stalling.
The valve consists of a thermowax material that expands or contracts depending on engine coolant temperature. It opens below 60°C (140°F) to allow bypass air to flow into the intake plenum. Above that temperature, the valve remains closed.
