Lack of Power, Sluggish
Definition: Engine delivers less than expected power. Little or no increase in speed, when accelerator pedal is pushed down part way.
POSSIBLE CAUSE ACTION
Contaminated fuel ^ Check for water or excessive alcohol in fuel, Testing and Inspection
^ Drain fuel tank and add clean fuel
Lead contaminated catalytic converter ^ Check for missing fill pipe restrictor
^ Replace catalytic converter
Low fuel pressure ^ Check fuel pressure
Pinched or collapsed fuel hose/line ^ Repair/replace as required
Throttle valve not fully opening ^ Check accelerator pedal travel (Floor mat/carpet interference)
^ Check throttle cable adjustment
Dirty air filter ^ Clean or replace
