Misses Under Load
Definition: Steady pulsation or jerking that follows engine speed, usually more pronounced as engine load increases. The exhaust has a steady spitting sound at idle or low speed.
POSSIBLE CAUSE ACTION
Contaminated fuel ^ Drain fuel tank and add clean fuel
Restricted fuel filter/line ^ Replace filter/repair restricted line
Low fuel pressure ^ Test fuel pressure
Fuel Metering ^ Plugged fuel injectors, perform Injector Balance Test
^ Perform injector service
