Surges at Steady Speed
Definition: Engine power variation under steady throttle or cruise. Feels like the car speeds up and slows down with no change in accelerator pedal.
POSSIBLE CAUSE ACTION
Insufficient fuel capacity ^ Check fuel capacity
Faulty fuel pressure regulator ^ Check fuel pressure
Contaminated fuel ^ Check for water or excessive alcohol in fuel
^ Drain fuel tank and add clean fuel
Dirty fuel filter ^ Replace fuel filter
Lean operating condition ^ Check computer controls, refer to Computers and Control Systems
Vacuum leak ^ Inspect vacuum hoses for proper routing and damaged lines
^ Check intake manifold and throttle body base
