Ignition Timing: Adjustments
1. Warm engine to operating temperature. Place Transmission in Park (A/T) or Neutral (M/T).2. Turn all electrical loads OFF.
3. Connect Rotunda Digital Tachometer/Multimeter (055-00101), or equivalent, to #1 plug wire.
4. Connect timing light.
Data Link Connector:
5. Connect Data Link Connector terminals STI and Ground with a jumper wire.
6. Verify correct idle speed. Adjust if needed:
Idle Speed 650 ±50 rpm
Timing Marks:
7. Check timing:
Base Timing: 10° BTDC
8. If not correct, loosen hold-down bolts and turn distributor to adjust.
CAUTION: Do not pinch the ignition coil to distributor high tension wiring when turning the distributor.
9. Tighten hold-down bolts to 19-25 Nm (14-18 ft lb)
10. Remove test equipment and jumper wire.
